  • 2 Replies
  • 1432 Views
kev123
i have noticed for the last couple of days 1 of my camera aint recording it picks up motion detection but there is no light on the camea that shows it is detecting any solutions ?
The only "light" on the camera that shows recording are the IR illuminators used for night vision (they show a dull red glow). The motion icon on the Devices tab (3 horizontal lines and a dot) should be black, not gray. Gray means disarmed. If gray, check that an appropriate mode such as Armed is selected. A reboot of the base may be useful.
JustAnElf2
Is your camera connected to power?  If it is, then you have the option of turning the little blue light on or off if the battery is fully charged.  Check the power supply to make sure it's properly connected, and the Camera LED option inside your smart app.
  • 2 Replies
  • 1433 Views
