I’ve only had my pro 2 system with 4 cameras for 3 days . All was well until today when one of the cameras displayed a very white picture. I switched off the night vision and the white screen disappeared but then I couldn’t see the picture as all was dark, turned night vision back on and the picture went white again. I’ve attached a photo. My other 3 cameras are fine. Thanks in advance for any help.
If you can turn it the night vision off and it goes away, it could possibly be a loose illimnator washing out the lens...
I would contact either place of purchase to replace or Arlo support for warranty
Yes thanks. That’s exactly right, when I turn off night mode it goes away then when I turn it back on it happens again.
Or something is nearby that's reflecting the IR back to the lens, such as a wall.
The only hing to look for is at bottom,,,,,is there a light colored surface?
If so, the illumination can reflect off of same and wash out picture.
Temp move the camera and verify it is not reflection
move camera and see if its still the same
Is there a film or anything else on the camera face? If not, open a case with support:
