  • 5 Replies
  • 2051 Views
3461Rfk8
Define Geo-fencing. I was told it stops the cameras when smart phone is in close proximity. It says is turned on. However get continuous beeping to phone and can see movement. I do not need Arlo at daytime when home. Would like it for night time when home.
5 REPLIES 5
JessicaP
Hi @3461Rfk8,
What phone device are you using for Geofencing? Make sure that you have the Geofencing setting as "disarmed" when it detects you near home.
3461Rfk8
How to set up geofencing?
3461Rfk8
smart phone is the Samsung Galaxy J 7V poer by Android, about 5 months old.
michaelkenward
Sensei Sensei
Sensei
Have you looked at the manuals?
Follow the links from here:
Arlo | Support | Default
The forum software makes it hard to embed links, but this may work:
User Manual
See the section Set Up Geofencing.
Also look at Schedule Your Camera Rules.
Just another user
  • 5 Replies
  • 2052 Views
