  • 1 Reply
  • 1137 Views
Gavinstick
Hi
Can you connect a Arlo pro 2 to your router if the wifi is swithced off at the router but is via a mesh system which broadcasts the signal (the first disc is connected to the router) ?
The Arlo system simply requires that the base be connected to your network via Ethernet. As long as the base can get an IP address from your router, the system will work since the dedicated WiFi between the base and cameras has nothing to do with your home network.
  • 1 Reply
  • 1137 Views
