I want to add a schedule to ARM my cameras from 12 am to 7 am. I also want to schedule my OUTSIDE ARM mode from 7 pm to MIDNIGHT (or 11:59 pm). The system won't let me add both. So two different modes can't be scheduled on the same day? Really? That can't be right.
I do that all the time. But I use two custom modes, I don’t recall if that makes a difference. I do recall I sometimes see odd behavior when creating a schedule, so try deleting everything on the schedule and starting over. If that doesn’t work, try two custom modes. Make a duplicate of ARM with your own name. “MY RIGHT ARM” or whatever.
As a PS;
Only one mode can run at a time and they can not overlap...
so you split up the cameras into groups as needed( by creating custom modes ) and then schedule the Custom modes as needed.
If you go thru midnight, you must split the time... up to 11:59pm and then the next day at Midnight onward
Yes. Same “day” is ok....same “time”, nope!
