  • 2 Replies
  • 3684 Views
Retired_Member
Not applicable
I hope someone here can help us.
Our Hub / basestation is on the internet and power is on. All 3 lights are green - BUT the Arlo APP keeps telling us "No Arlo-units have been found".
I have uninstalled the app on my Samung, and today I deleted the ARLO - to start ALL over.
Nothing is working !!!
The Camera LED being green means the base is already claimed which is why your attempts fail. Is this a new installation? If so, hold the reset button for >10 seconds until the LEDs flash amber. Let the base reboot and try again.
If this is an existing system, you should remove all devices in Settings, My Devices first. See if the Camera LED becomes either amber or off after the base reboots. If not, use the reset button as above and start fresh.
Retired_Member
Not applicable
Thank you  !!!!!
it worked - 10 sek pressing the reset.
My Arlo is up and running again - and I am happy happy happyyyy 🙂
  • 2 Replies
  • 3685 Views
