I've got a camera that won't sync with the base. I've tried switching out won't, resetting the base (cameras don't have a reset I learned). Anyone have any clues as to what I'm doing wrong? TIA
Exactly what have you tried? Was the camera previously connected? If you're trying to then reconnect it be sure to remove it from Settings, My Devices and try again. Also, what are the base LEDs showing?
