HW Version H4
Firmware 1.125.13.1_1188
I am using a Netgear Charger and the cable, but I have started getting the following error: "A charging fault has been detected. Unplug and reconnect the charger from the camera side of the plug. If this error message persists, see KB article for Charging Faults." I have tried resetting the camera, reboot the camera, removed the battery, everything which I could think of, but I am still getting the error message listed above.
Also, all attempts to contact have failed, please advise.
Could be an issue with the charger itself. Does it work on any other camera? Have you tried another charger that support Qualcomm QuickCharge which supplies both 5v and 9v outputs?
I have tried multiple chargers and the same chargers work with other 4 Arlo Pro 2 cameras.
Please advise.
Also, all attempts to create an Arlo case have failed, and hence I came here and posted my question. I am still in the 1 year warranty period.
Using the Contact Support link at the bottom here is the only way to get a warranty claim going. We can't fix a hardware problem.
