Arlo Pro 2 Camera Stopped Working Completely
  • 4 Replies
  • 3818 Views
Retired_Member
Not applicable
Hi all!  I recently ran into issues with one out of five cams I've had operational for a year.  Initially, it seemed like the battery wasn't holding charge.  After several attempts at recharging, this still wasn't solving the issue so I got a new battery.  Initially I had issues with it running continuous records even without motion.  The cam was resynced and worked fine for about two days, and now it's "offline" again.  I know it isn't a battery issue and not a sync issue.  All firmware are updated.  I'm more convinced there is something wrong with the camera itself.  Any help would be appreciated!  Thank you.
Whenever you suspect a hardware issue, open a case with support to get the claim in during your warranty period. You may be lucky if you're still within the typical 1 year warranty but if not they can try to help but you may need to buy a new camera instead of being able to get one RMAed.
Retired_Member
Not applicable
So what you're saying is I now have a 100 dollar paperweight as I'm outside the warranty.  Is there any place to get it refurbished?  I do not enjoy losing 100 dollars.  If not, then Netgear really needs to reevaluate standing by their customers as this is a quick way to lose them.  Thanks.
What consumer electronic equipment can you get repaired? If your TV dies, good luck fixing it since it will cost as much as buying a new one that has more features.
There's an old link in the original Arlo section here that points to Arlo selling refurbished components. I have no idea if it's still valid but:
https://store.arlo.com/arlo-products
Retired_Member
Not applicable
You're not wrong.  However, most TVs will last longer than a year and change.  It's just surprising to me that the tech has screwed up, that's all.  Thank you anyway.
  • 4 Replies
  • 3818 Views
