My arlo pro 2 camera is not detecting. Motion and I have it plugged in for 24/7 recording. Its recording but it doesnt show me the activity under the library. Does anyone knows how to fix it ?
The cameras even plugged in do not record 24/7 ( unless you have the CVR option ) but get triggered by motion to record...( simple answer )
Make sure your not trying to shoot thru glass as it will block the IR that is used for detection
