  • 12 Replies
  • 7510 Views
  • 2 Likes
  • 5 In Conversation
NTNH
Hi Everyone,
I bought an Arlo pro 2 base station and four cameras. Setup easy and work well.  However, two weeks now. One camera for my front door does not detect the motion anymore.  I tried motion detection test, no orange light but two one-time flash red lights. The other three work ok right now. It is raining for several days, here. I am not sure if that affects the camera.
Anyone faced or facing the same issue and can help me with that?
NTNH
I took it down and remove the battery and put it back. Now it works.
12 REPLIES 12
Maybe the battery needs chaarging?
NTNH
Thanks for the reply. The battery still 70% remaining. I can try to charge it until full, however, it should not be like this.
Spec battery life is for <5 minutes of recording and live viewing per day. Have you been following that?
NTNH
srleonard93
Hello,
Can anyone help me identify why one of my camera's stopped detecting movement and stopped alerts? I have tried to remove the battery, delete the camera and resync and no luck.
ShayneS
@srleonard93
What Firmware is your base station & camera running?
srleonard93
1.12.0.0_27099
That's for the base but what about the camera? SHould be 1.125.11.3_26229.
What mode are you using? Is the a rule for the camera in that mode? When you delete the camera and resync, any rule for that camera in a custom mode is removed and has to be readded.
zilinsky
Yes one of my cameras motion dector is inoperable. I'm looking for a fix.
Is the camera armed in you rmodes? What have you tried?
NTNH
Yes, armed
Remove the camera from Settings, My Devices and resync. ANy better?
  • 12 Replies
  • 7511 Views
  • 2 Likes
  • 5 In Conversation
