I purchased two Arlo Pro 2 wire-free cameras to go with my 3 Arlo wire-free cameras. Unfortunately, all camera motion detection and notifications have practically stopped. I cannot afford to pay for a subscription, so I use the cameras and a USB memory stick. Even the original Arlo cameras worked so well in the past. However, it seems that since I do not pay for a subscription, it is negatively affecting my cameras. Also, the Arlo app I used with my J3 Samsung camera worked so much better than it does with the S10 Galaxy android phones. My husband and I are so extremely frustrated, we are about ready to give up on Arlo completely. Yes we have zones set, yes we have cameras placed properly, yes we have stong batteries or plug in cables. Also, the night vision on all cameras has become so
Hi @KayLor
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Hi @KayLor
Have you tried to remove the camera from Settings > My Devices > Re-Add them?
Also, the Arlo Pro requires a smart subscription for activity zones. The Arlo Pro is not capable of AC powered activity zones, but the Pro 2 is. The smart sub will allow the Pro camera to be capable of Activity Zones off battery power/while plugged in.
Hi @KayLor
I would suggest contacting customer support regarding this. I have attached the link here for you - Arlo Tech Support
