Arlo Pro 2 Base Station will no longer Connect to Internet - Netgear CG3000 - 1STAUS Router
  • 1 Reply
  • 572 Views
emsy_j
Purchased my ARLO pro a few months ago - set it up within 5 minutes - was so easy.  And then 2 weeks ago the base lost connection to the internet - Amber light.  My router is a Netgear CG3000-1STAUS.  i've unplugged replugged, checked cords, synced - all the simple stuff a non IT person can do.  What are recommendations from here - that are easy to do.
michaelkenward
Sensei Sensei
Sensei
Recycled (turned on and off) the whole network?
Modem/router first. Then base station.
Reset the hub?
By the way the CG3000 is a modem/router, not just a router. Anything else on the network?
In extremis, reset the modem/router and rebuild the network from scratch.
Just another user
  • 1 Reply
  • 573 Views
