Arlo Pro 2 Base Station Differences
  • 4 Replies
  • 9537 Views
  • 2 Likes
Blag
 How does the base station differ on the Arlo Pro 2?  Is it any different at all - i.e. is it just the cameras that are different?
Blag
Any response to this question?
mluck94
I’d like to know this as well
NetBox
I was communicating with Netgear support earlier today and they confirmed the Arlo Pro and Arlo Pro 2 systems use the same base station.
So it is only the actual cameras which have been upgraded from the Pro to Pro 2 versions.
I asked if it was possible to purchase the Arlo Pro base station and buy separate Arlo, Arlo Pro and Arlo Pro 2 cameras and mix and match my configuration. They said what I thought, that it was perfectly fine and the base station from the Pro and Pro 2 were the same.
mluck94
Awesome, thanks for confirming it.
  • 4 Replies
  • 9537 Views
  • 2 Likes
