I have Arlo Pro 2 camera with an Arlo Pro base. But I do not see any icon that says "start alarm". Where is it, what does it look like? I read that it is a "bell shaped" icon but the closest thing I see to a bell shape is the speaker shaped icon on the bottom of the screen.
That's because the siren in in the base, not the cameras, assuming you have a Pro base.
Assuming you have the latest app, the manual siren icon is at the top of the Deices tab, the red and white shield with an exclamation point.
Thanks. I found it and I tried to use it. I got a message saying "Are you sure you want to start the alarms?" and I answered "Yes." But then, nothing... There was no sound from either of the cameras.
Thanks!
