Arlo Pro 2 Alarm Duration
  • 3546 Views
AussieSean
How do I adjust the length of time the Alarm sounds? There used to be a setting attached to each camera but it is no longer there.
Streak2
Master Master
Under mode, select a camera and then add device where you can select the alarm. Once selected you can then adjust the duration.
Streak2
Master Master
Xman22
Not solved yet, not able to change the duration as suggested, there is no way to add device under mode.
Edit your mode and then a rule. Use the Add Device selection near the bottom to add the siren. Edit the siren to change settings.
  • 3547 Views
