If I have the Arlo Pro 1 station do I need the Pro 2 station or Can I just buy the Pro 2 cameras?
You can use the Arlo Wire-Free base station, so an Add-on camera will work. But the original base station does not support the Alarm or USB drives.
____
Please click
KUDOS or REPLY If you found this helpful.
Please click
Mine does? It’s the Pro base station that comes with the 720p cameras.
