I want to add a 2nd base station to my system. I have the basic system. (I want to increase the camera signal strength)
Do I need to have both base stations connected to an ethernet cable?...or just my #1 base station?
What are the steps to connecting the 2nd base station?
To add another base, it's the same as the first.... Plug in power and Ethernet cable then use ADD Device from your main screen after logged in
Get WiFi extender with ethernet port (If money not problem the Nighthawk 22000 is great, better range/speed), then find beast WiFi spot for Extender that also has best Camera Signal strengh. Try different locations till you get best overall results
I wound up buying this device. It seems to be working well. AV1200 Gigabit Passthrough Powerline Starter Kit
