I have 2 activity zones 1 large zone (working fine) and a smaller one which overlaps zone 1 a bit. Zone 1 triggers motion fine however zone 2 does not. This is a powered unit.
Thanks in advance for your help.
Steve
retsteve,
Have you tried to reboot your base station & test again? Have you tried to create this zone on the Web Portal or the Arlo Mobile App?
Shayne,
Yes I have tried the reboot with no change. The 2 zones were created on the Web Portal.
Steve
retsteve,
Can you try to delete these zones & re-create them in the Arlo Mobile App and test again.
Tried it with no change.
Is it possible to adjust the 2nd zone with the issue a bit larger or smaller & see if this triggers the system.
Shayne,
I have made both zones as close to the same size as possible and it still only wants to recognize only on of the zones.
Steve
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
Shayne,
I have contacted them and they did not have an answer but opened a case and have not gotten back to me. Thanks for your time.
Steve
retsteve,
I will contact support and let them know you have not been contacted. Hope you have a great Thanksgiving & Thank You for your patience.
Shayne,
Thank you and same to you.
Steve
