Arlo Pro 2 - 3 Cameras - 3 Mounts, 2 Mount Screw Sets?
Hello,
I just received my Arlo Pro 2 (3 camera) kit. The packaging contains 3 cameras, 3 wall mounts but only 2 wall mount screw sets. I thought it was a packaging error initially, but then I looked at the contents list on the box and it lists exactly that.
What is the purpose of supplying 3 wall mounts but only 2 sets of mounting screws? The wall mounts are useless without being attached to a wall as they stick to the back of the camera, so the only way you could mount the camera to a wall mount without it being on the wall would be to aim it at the ceiling.
I guess if a thief gets in my roof cavity and cuts a hole in the ceiling just above the camera it might help track him down.
Can someone explain the logic for me? It's hurting my head, and now I'm going to have to track down a wall mount screw set sold separately I guess.
Thanks!
Sorry, dumb question. I actually read the manual. Turns out a "mounting screw set" has enough screws for 2 cameras. I assumed two screws per mount.
Please delete topic.
