Arlo PRO 2 VMC4030P stop working
  • 5 Replies
  • 2907 Views
  • 3 Likes
Aegidius
ISSUE:
  • The camera stop working. The only action that it perform is a led blinking when i plug the battery or the power supply.
INFO:
  • I bought with Arlo Pro2 VMS4430P kit by Amazon.
  • The camera and the entire kit work only inside my home. Never been outside.
  • I don't know the firmware version because the camera doesn't work, but I periodically check for the firmware update in all my Arlo devices.
Thank you in advance for the help.
ShayneS
@Aegidius
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
5 REPLIES 5
Are the base station LEDs showing good power and internet status? https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
If they showing good status, then have you tried removing the camera from your account and re-adding it?
Aegidius
The base station led are ok and the other cameras connected work fine.
I removed the camera but It's impossible to add it again because when I press the sync button on the camera nothing happen.
Thank you.
But you are seeing the blinking blue light on the camera?
Assuming yes:  Did you try also pressing the sync button on the base (instead of using "add device" in the app and web client)?
Aegidius
@StephenB Unfortunately no. As I said, nothing happen when I press the sync button.
ShayneS
@Aegidius
  • 5 Replies
  • 2908 Views
  • 3 Likes
