Arlo Notifications stopped working on IOS 15.0.2. Tried logging out and restarting iPhone.
Arlo Notifications were working perfectly, before I updated to iOS 15.0.2.
I have iPhone 11 Pro, I am not getting Arlo Notifications. I have logged out, restarted my iPhone, I have my notifications for Arlo ON
Hey Jackie10,
Try referring to this article to troubleshoot where you're not receiving notifications anymore: Why am I not receiving Arlo notifications on my iOS device?
I tried this already, and this is not a fix.
The problem started to occur when I upgraded to iOS 15. Can you pls fix your Software for iOS 15 and let me know when its fixed
I would suggest to try uninstalling the Arlo app, restart your iPhone again and reinstall the app to see if that helps.
If you still have issues where you're still not receiving push notifications, please navigate to Settings > Support in the Arlo App for service options available to you.
This is wide problem on iOS 15 - Please look at this link
https://www.iphonetricks.org/how-to-fix-notifications-not-working-ios-15/
@Jackie10 wrote:This is wide problem on iOS 15 - Please look at this link
That is an IPhone issue for other apps also. Did the fix work for you?
