Arlo Dual Battery Charger fails. Charger shows orange when charging and battery has about 20%.
  • 1 Reply
  • 1551 Views
Australien
Luminary
Luminary
My Arlo Dual Charger suddenly doesn’t charge my batteries anymore. The charger should turn orange to show it is charging. The battery has about 20%. I can charge the battery if I put it in a camera and charge the camera but why doesn’t the dual charger work? I checked all contacts and also swapped it on the charger but no change. The lights are constantly green.
Make sure your using the original adapter;
Note: You must use the Arlo Charging Station adapter and cable or the Arlo Pro camera power adapter and cable when you use the charging station
read this ; https://kb.arlo.com/1239221/What-do-I-do-if-my-Arlo-Charging-Station-won-t-charge-my-Arlo-Go-or-Arlo...
this may also help   ; https://www.arlo.com/en-us/images/Documents/ArloPro/arlo_pro_charging_station_installguide.pdf
  • 1 Reply
  • 1552 Views
