How to change wifi channel to another one? Causing interference.
  • 1 Reply
  • 1818 Views
TGorb
Since installing my system, many of my other wifi items connected on the 2.4Ghz band are dropping connections. Find that this product mirrors my wireless router and broadcast over the same channel causing interferrence. I am unable to set the VMB4000 base station to another channel. Anyone have success in doing this?
You can't change anything in the base. However, you can move the base away from the router or use a WiFi or powerline extender to remove it from the router's proximity completely.
  • 1 Reply
  • 1819 Views
