Arlo Cameras Pro 2 too cold at 43 degrees
  • 1 Reply
  • 412 Views
Gordons
The temperature outside is 43 degrees at this moment. One of my four cameras says it too cold for the battery to work and it must be brought inside. However, I have not received this warning before and all four cameras worked this winter when the outside temperature was down to 15 degrees Fahrenheit. Does anyone know why is it showing that warning when it’s not even cold outside?
@Gordons wrote:
The temperature outside is 43 degrees at this moment. One of my four cameras says it too cold for the battery to work and it must be brought inside. Does anyone know why is it showing that warning when it’s not even cold outside?
Clearly it shouldn't be.  Are you seeing this on both my.arlo.com and the app?
I suggest removing the battery and then reinserting it, and see if that clears the error.
  • 1 Reply
  • 413 Views
