Can Arlo Pro 2 be connected to 5G network?
  • 2 Replies
  • 2288 Views
fetzablu
Can Arlo Pro 2 be connected to 5G network? I am currently running on 2.4 and the signal is a little spotty as my router is quite a distance away from the router.
No. It only connects to the base station using a closed 2.4 ghz wifi connection.
FWIW, 5 ghz wifi has a shorter range than 2.4 ghz wifi.
fetzablu
Thank You
  • 2 Replies
  • 2289 Views
