  • 7424 Views
duggyhow501
Hi y’all, my arlo Base station internet light is staying Amber. My pc is doing fine with my extender but the base station still won’t connect to the internet. I replaced the base station with a new one and it is still doing the same thing. The extender is new too. I thought it was the router, then I replaced the base station. The router in another room is connected to another base station that is working fine so I don’t see how it could be the isp. Please help, thanks.
duggyhow501
Hi, resetting the main router did the trick. Thanks for your help.
temp move the base OFF the extender to the router and see if it works there. ( or swap them )
(eliminate possible other issues to narrow down problem )
duggyhow501
Hi, thanks, I will try that. Would it be because I used the ABS or is it APS? The button used to connect quickly without going thru setup. I’m wondering if this has caused the trouble. I will try setting up the extender going thru the setup instead. I’ve tried resetting everything accept the router so I’m gonna try that too.
duggyhow501
  • 7425 Views
