My Arlo Pro 2 has worked great until just a few weeks ago. All of a sudden my recording are showing up under my devices, next to the settings icon and not my library. I have restarted my base station and my iPhone. How do I correct this issue.
Are you seeing any recordings in library? The recordings icon for new recordings has always been there and if you select it takes you to the library for just that camera selection. In library try unselecting (the x beside the name)for that cam such as door and see if others are there. I always just go to library so I don't run in to that. I think that's what you were talking about.
Just to clarify when you say they are now showing up in device section do you mean the symbol with the number of new recordings or the actual recording there?
Again, Thanks for the input!
It finally started working properly. Hopefully this is permanent.
Reset it last week but the problem has reoccured several times since.
Thanks for the support!
My Arlo just reverted back to storing my videos under the Device section of my Arlo app again. My camera recordings are not showing up in the library as they used too. When I go to the device section at the bottom left of my home screen, in the individual cameras, I see the number 2 on the right hand section under my front door camera recording, beside the device settings icon ( further to the right). Once I touch the number 2 my recordings then transfer to in my library. Any help with this would be appreciated!
I am still having problems with the library not showing all the recordings.
When I arm the Arlo and then walk around the house, I get all the notifications on the first iPhone screen (with the date and time). However, once I enter access the screen with all the apps, I only have 1 listed. Once I go into the Arlo app, I only have three videos that show up.
I have replaced my app, I have also reset my base station, and paired the cameras and still have the same problems.
Do you have the latest app version 2/18 installed? Which iphone are you having this issue with?
Yes, I have version 2/18 installe. I have an iPhone 7 Plus.
Hi @jane27
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
