Arlo 2 cameras
  • 1 Reply
  • 1264 Views
Parker757
I switched to the new Arlo software and this was a downgrade.  Can someone tell me how to keep the cameras active?  I can turn the cameras on a watch a particular area and then turn them off, but if I want to keep them on, I get a message that says the cameras must be wired.  They will not connect while on battery power as in the old application.  This is a terrible change.  I only use battery power.  None of my cameras are wired.
This sounds like you have activity zones set up. Zones are processed by the servers when battery-powered which requires a subscription. AC powered cameras can process the zones in-camera. If zones are the issue, remove them and the message will go away.
  • 1 Reply
  • 1265 Views
