  • 1732 Views
thekritic
Since Pro 4 power and mounts are different than the Pro 2, I was wondering if we can still purchase Pro 2 to add to an existing Pro 2 system?
Dannybear
The pro2 model is no longer manufactured by arlo.
If your keen you can still buy used or refurbished units on the internet.
If you go this way consider the supplier warranty as arlo warranty expires after the first owner and stolen systems are usually locked to the previous owners account unless released.
thekritic
Thanks Dannybear! I just didn't want to replace power cable and outdoor mount, since Pro 4 hardware is totally different.
Both the Pro 2 and the Pro 4 mounts use standard mounting screws, so any existing screw mounts would work.  The magnetic mounts would not.
The power cable is of course different, the Pro 4 using the magnetic connector instead of microUSB.
Note the Pro 4 does require a subscription to get cloud storage (the 7-day free storage isn't available for any of the newer cameras).
  • 1733 Views
