Netgear,
I'm running 12 Arlo Pro 2 cameras and have some input that I'll send to your support directly as well but want to share here in case you're reading... The Arlo Pro was a great system and I was hoping the Arlo Pro 2 would be even better, but I'm noticing some shortcomings...
Please remove the not plugged in warning for every camera in the Arlo app. Comes up every time I launch the app and I have to click "Ok, I got it" on every camera, just annoying when you want to see the thumbnail preview. Put the info message elsewhere like when a user tries to enable the CVR or video zones.
Nightvision - On battery, the nightvision on the Arlo Pro 2 vs. the Arlo Pro is not good... Haven't tried on power, but don't plan to use power. I'm really disappointed in the quality of the nightvision overall. There are a lot of dark black areas and the picture just isn't lit up as crisp with the Pro 2 vs. the Pro. Also, when motion is detected, some cameras record pitch black for a second or so and then as the IRs illuminate the picture the nightvision starts to show up. Never had this with the Pro version, worked like a champ. I hope this can be resolved in a firmware release so that I don't have to buy all new cameras...
Arlo Pro 2 ups the game by introducing 1080p resolution, a wider field of view compared to previous generation cameras, along with a host of new features that include versatile power options, 2-way audio, and advanced motion detection with activity zones. All of the above is done while maintaining the things our users love and have become synonymous with Arlo: Simple wire-free setup, Weather-resistant ruggedness, Optional 24/7 continuous video monitoring, local backup storage, and up to 7 days of free cloud storage. Not to mention, Pro2 is backwards compatible with all previous generation accessories and base stations.
The same applies at night time, where in each frame, a user can literally see more in every shot. By upgrading our image technology, we also upgraded our motion and night vision capabilities.
Some users have requested that we increase the overall “brightness” of our cameras. While seeing brighter, albeit subjective, is a valid request - simply making images brighter may not always apply to the scene that is being recorded. Every user’s setup is different, as well as the type of scene and image being captured. One fix for all situations can often result in tradeoffs in other aspects of the image quality. As an example, simply going brighter can result in oversaturated images dependent on the user’s scene.
What we did focus on addressing however, was overall image quality during high motion. Especially in security driven use cases where the action being captured could be a vandal at your front door trying to run away, we wanted to enhance the overall quality in those situations. Over the weekend, we released a FW update that reduces the amount of compression when fast motion is detected. This results in better quality videos, with minimal change in overall file size being allocated to capture that motion event.
Arlo aims to up the game in image quality with each new generation of product, and we know our users will enjoy literally seeing more in every shot, seeing more details, as well as crisper video even in fast motion scenes.
-Arlo Development Team
Nightvision - The nightvision on the Arlo Pro 2 vs. the Arlo Pro is not very good... I'm really disappointed in the quality of the nightvision. There are a lot of dark black areas and the picture just isn't lit up as crisp with the Pro 2 vs. the Pro. Also, when motion is detected, some cameras record pitch black for a second or so and then as the IRs illuminate the picture the nightvision starts to show up. Never had this with the Pro version, worked like a champ. I hope this can be resolved in a firmware release so that I don't have to buy all new cameras... Thanks for listening.
djdannis,
Can you post screenshots of the Night Vision issue you are describing? Also, if you have a Pro (non-Pro 2) that you can place next to the Pro and take a screenshot as well for reference that may help us better understand the issue.
James,
Appreciate the attention and reply. Here is a video of the slow night vision issue. I don't have my Arlo Pro first gen anymore, but will try to pull some recorded video to see if I can get a comparison. Thanks.
James,
And here are two pictures of the Arlo Pro vs. Arlo Pro 2 nightvision quality difference. The brighter more illuminated picture on the top is from the Arlo Pro and the bottom dimmer illuminated picture is from the new Arlo Pro 2. Almost like the IR LEDs are not as powerful. I'll try to get another example this evening to post. A difference that I hope can be resolved in this new hardware version. Thanks.
Now that I read these threads, I do infact notice a lot of reduced night vision versus the Pro1. Something has changed on the Pro2. I never noticed until now because I always leave my outdoor lights on, and they are quite bright. When I turn off all outdoor lighting, the video get pretty close to pitch black in all the near distance areas, similar to what the others here are describing. Hope Arlo pushes out a firmware update.
James,
Here's another example of the nightvision difference between Arlo Pro and Arlo Pro 2. The brighter top image is the Arlo Pro and the bottom darker image is the Arlo Pro 2. Please advise on these issues and let me know how I can help. I and a few others really hope there is a simple solution. Thanks.
Im having the opposite problem, Night vision is "white-washed"
Hula_Rock wrote:Im having the opposite problem, Night vision is "white-washed"
Strange hula... Hope Netgear provides some feedback with solutions on this thread soon...
djdannis wrote:Netgear,
Update for the community: Netgear removed the Pro 2 app warning as requested in the latest Arlo App Update - THANK YOU James and team for the prompt response on that.
James, any feedback on the nightvision issues? Thanks
Hello? James? Haven't heard from you for a few days now...
I'm going to send you a PM as well. If there is no hope, I'm going to return the 12 Arlo Pro 2s I have. Another annoyance of the Pro2 over the Pro is that I keep getting false alerts. I've spent the past week now tweaking and tweaking and tweaking... Literally all night and all day tweaking with false events still occuring. Many of my cameras are well below the sensitivity thresholds my Arlo Pros were set at. Evidently to the point now I just missed a motion event of a package drop off that was 4-5 feet in front of the camera. Not cool.
Please give me some indication.
djdannis,
I've escalated this topic seeking clarity on Night Vision behavior and the expectation vs the original Arlo Pro. I do not currently have any updates at this time. I will provide more information as soon as I can.
Is anyone else having low light and visibility issues at night with Arlo 2 ? Sound is lower than the Arlo pro 1 also. Arlo do you do any RND before you launch new products?
Yes, recording audio is certainly at a lower level and I find the night vision to be almost washed out a little.
I also am having the washed out issue. Here are my shots from the same location of the Arlo Pro the morning before and the Arlo Pro2 the next morning. Pro
Pro2
Yup, same degraded night quality here
I also have a couple videos that recorded pitch black and NEVER recorded properly
Not to mention, yesterday beinig 10/20, videos from 10/1 showed up in my library (on the free plan)
General wonkiness
Rick
My night vision is on the other spectrum, much darker in general, yet the top of a painted fence is washed out
Rick
Just recently added several outdoor Arlo Pro 2 cameras for better resolution. These replace Arlo Pro cameras which worked fine. These new cameras produce grayed out, grainly night vision images that essentially obscuire visibility, The sticky plastic piece that covers the lens and outer wall of the camera during shipping has been removed. These cameras are connected to the existing arlo pro base station as opposed to adding the arlo pro 2 base station. Thoughts on resolution appreciated.
Not sure if it's a hardware or firmware issue. If firmware, hopefully a fix could be made available soon. We'll see.
So I called support tonight, finally got my Grant Access issue fixed so I then asked about progress on the poor night quality and she told me they aren't aware of any issues. Put me on hold, came back and said the same thing. I told her to go back to her supervisor and tell them to stop misleading their customers. After another 10 mins of telling her about all the comments on their own community board, she finally said they were aware of it but just a few cases.
She then encouraged me to post my concerns on the community so they can get more visibility, this way they will start working on the case
I highly suggest everyone call support and report it, apparently they need to hear from more of us
NOT impressed Netgear
Rick
I just talked to support
1. She claimed they are not aware of any night quality issues
2. I provided a sample, she confirmed it was bad
3. Told me to remove it from my system, remove and replace the battery then re-add it
Stellar... NOT
Rick
I just purchased the new Arlo Pro 2 system this morning and installed it this afternoon. My old Arlo Pro cameras worked flawlessly before the change. Now, I'm kicking myself in the butt for spending $500!! If it ain't broke, don't fix it...should've listened to myself.
I am also getting the hazy, cloudy night videos/images. These new cameras are at the same location as my old ones were and I did remove the protective film in front of the cameras. Hope this gets resolved ASAP, or I will be returning it.
For the folks who have both Pro and Pro2, do you see any improvement in quality whatsoever in Pro2? It is supposed to be 1080p but quality is nothing near 1080p and is more 720p.
