I’ve replaced the solar panel & cable for charging my Arlo pro 2 because it came up KB charging fault. It worked fine by put after 3 days it’s back again. KB charging fault.
Does anyone have any idea why.
Also on another pro it’s seems to be discharging rather than charging. The battery only lasts 3 days even after charging via the mains & not been used. It’s also a new battery.
2 problems, I’m not happy.
Hi @SanmigQueen
Please contact the Support Team to further investigate this charging fault error. You will find several options for contacting support in the provided link. Arlo Tech Support
