App reports everything is offline
  • 21 Replies
  • 4650 Views
Sheemo1
Why in the app does my base station say off line along with my doorbell and two cameras but in the Apple home app everything is working in real time ?!?!
21 REPLIES 21
ShayneS
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Sheemo1
Currently shut off base and and unplugged it and disconnected the Ethernet  connection all lights are green on the base station as well and can currently see all camera and watch live footage using apples home app
ShayneS
Can you try removing and re-installing the Arlo app?
Sheemo1
I did and no changes
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Sheemo1
Cost ?
@Sheemo1 wrote:
Cost ?
You do need an Arlo Secure subscription (which you could cancel later).
ShayneS
I see your base station is reporting as offline. What are the LED status lights displaying on the front?
Sheemo1
All green
ShayneS
@Sheemo1 Are any other phones showing the devices as offline? Does the web portal on a PC show offline as well?
Sheemo1
How do I get to web portal ?
ShayneS
Sheemo1
Looks like portal requires a subscription
ShayneS
@Sheemo1
You should be able to log in to your account to live stream your devices.
Sheemo1
Cannot see any dashboards with camera can you please tell me how to get there
Sheemo1
All I see is two choices Arlo secure and Arlo safe
Are you using a PC?  Or are you browsing from a tablet or phone?
You need to use a PC (Windows or Mac).
Sheemo1
Tablet
@Sheemo1 wrote:
Tablet
When you use a tablet or a phone,  my.arlo.com just gives you the ability to manage subscriptions.
That is why  @ShayneS suggested you use my.arlo.com using a PC.
Sheemo1
says everything is off line on web
ShayneS
@Sheemo1
I have escalated this for you and support will be reaching out as soon as possible.
  • 21 Replies
  • 4651 Views
