Why in the app does my base station say off line along with my doorbell and two cameras but in the Apple home app everything is working in real time ?!?!
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Currently shut off base and and unplugged it and disconnected the Ethernet connection all lights are green on the base station as well and can currently see all camera and watch live footage using apples home app
Can you try removing and re-installing the Arlo app?
I did and no changes
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Cost ?
I see your base station is reporting as offline. What are the LED status lights displaying on the front?
All green
@Sheemo1 Are any other phones showing the devices as offline? Does the web portal on a PC show offline as well?
How do I get to web portal ?
Looks like portal requires a subscription
Cannot see any dashboards with camera can you please tell me how to get there
All I see is two choices Arlo secure and Arlo safe
Are you using a PC? Or are you browsing from a tablet or phone?
You need to use a PC (Windows or Mac).
Tablet
says everything is off line on web
