App Loading Screen Takes 10+ Seconds on iOS - SOLUTION
  • 0 Replies
  • 1461 Views
  • 1 In Conversation
DigitalUFX
Hey everybody. I figured out how to fix the Arlo app taking 10+ seconds to load on iOS. Just make sure you block notification from inside the app, NOT from iOS. I was getting 100+ notification/day, so I turned them all off from iOS settings, this causes the loading screen to hang for 10+ seconds every time I open the app. Turning notification back on from iOS, and turning off the individual cameras stops the notifications, but the app loads in 1s instead of 10+.
Hope this helps.
Also, Arlo, kindly fix your app 🙂
0 REPLIES 0
  • 0 Replies
  • 1462 Views
  • 1 In Conversation
