  • 6108 Views
shaolin95
Hello,
I just updated the app and set the PIN but when I tried Alexa to discover devices it did not find anything new and I cannot find where to enable the Disarm by voice option.
Help please.
ArloAlex
Hey @shaolin95  - if you are not seeing the SmartHub or base station in the Alexa app after asking Alexa to discovery devices, you may need to remove and re-add the Arlo skill in Alexa. After that, you should be able to see your VMB4000 in the devices list. You'll then need to "edit" the Voice code in the Alexa app and select "Existing security system PINs."
Let us know if this helps - thanks!
ArloAlex
shaolin95
Thanks that worked!
Can you Arm specific modes like one I have named Outdoor which only enables the outdoor cameras?
Or maybe I can just edit the Disarm to keep the outdoor front camera on since I RARELY turn that one off..
ArloAlex
Great suggestion - for now, it’s just Arm and Disarm for the entire Base Station via voice commands to Alexa.
  • 6109 Views
