  • 1 Reply
  • 774 Views
greyowl
Anyone have experience with the cameras at minus 30-40 degrees?   I have 2 outside , plugged-in cams.   At these temps , will they freeze up at low temps & then re-activate in warmer weather or do I need to take them down to protect them?  There are no batteries , only the electronics to consider , I would think,   Any experiences appreciated.  Thx
I've never had the Pro/Pro2 go below -10F...
But, after they shut down and weather got warmer they came back fine.
YMMV as -40 is a bit colder but I don't think there will be an issue
As to batteries, they won't charge belwo 32F anyway as it can damage cells
( funny thing is that the old original Arlo on 4 batteries never shut down, other than a voltage sag due to cold, they worked the whole time )
  • 1 Reply
  • 775 Views
