I recently purchased wall mounts and skins for my Arlo cameras but once installed and hooked up, the night vision no longer works on any of the cameras and one of the cameras just flickers/clicks 24/7. I've reset the base to no avail. I've switched the settings on and off for night vision but no avail. What's wrong?
Pull off skin and mount, pull battery and wait a min, reinstall to reset camera and test.
Use in dark room, you can see the night vision as a slight red glow arounf the lens
Hi, thanks for the tip. I pulled the skins off and kept them off and then reset unit and now they work fine. 🙂
