Is there any way there can be an option to mute the notifications longer than 24hrs? While at home, I’m getting several alerts about motion and it’s very annoying. Thanks
Hey Andre907,
Currently the mute notification supports up to 24 hours. However, there are different ways to turn off push notifications if needed. Feel free to read about them below:
Mute on the update only lasts 24 hours - I want it off all the time, not a daily 24 hour select
Hi arlo4al,
If you want to turn off push notifications, feel free to read these articles:
The inability to mute notifications in the app is ridiculous. I have hundreds as cars pass all day long. So, I have to mute for 24 huours every single day. To make us decipher how to go in and set up rules and modes etc..... Is unacceptable. You changed it - you caused the problem. I cant figure out how to solve it. After reading and trying for 45 min I have to give up. I am the farthest for tech savy you can find. So, if you care to have people like me as clients - you need it to be simple (Like it was). To not be passive aggressive - I want it to be known and not subtly suggested: I am freaking pissed off and I get triggered every 24 hours my phone starts going off and I have to mute it. I have called Vivant to see what they are about.
The Arlo answers here from JessicaP are not helpful at all because they will also block visual notifications, which are helpful, while blocking the totally annoying audible notifications. Having to reset the Mute Notifications every 24 hours either interrupts my sleep, family time or business meetings. Permanently muting notifications was an option with your previous software, which is why I invested in 11 cameras. This inability to mute notifications permanently has made this entire system useless and completely annoying. I'm strongly considering returning all of it to Best Buy.
The arlo app is just lacking in so many way. Why did you guys ever rebuild the app? It's not any better than before - it's worse. You should have put that budget towards improving your prior app.
Here are a list of features it needs:
The app needs the ability to turn off notifications permanently.
Geofencing for turning notifications on and off. Not geofencing to let you know when someone is in a zone.
Geofencing to turn recording on an off.
Scheduling of notifications that is separate from scheduling for recording.
