  • 1120 Views
rdilauro
Luminary
Luminary
We just installed two Arlo Pro 2 cameras in our ballfield to protect over 100 boats that are stored.  We setup the camera, so that ARLO is readable right side up and that the charging ports are on the bottom of the camera.
When we look at anything in library, all videos are up side down.  I've gone into MY Devices, for each camera and the Video settings to check for the 180 toggle switch  When I toggle it in that window the image is correct.  (There is no save button unless I change the zone)   When I go back to the library all images are upside down.
How can I correct this so that all existing and new images will be right side up.
Thank you
That's something I have seen posted here before.  Are both cameras doing this?
Have you tried restarting the camera?
The old videos will still be upside down but new ones should be correct. Can you verify that?
rdilauro
Luminary
Luminary
Yes, restarting the cameras corrected the images
  • 1121 Views
