Sometime within the last 2 days, the fingerprint login within my Android Pixel app stopped working and always said "Your session has expired. Please log in." but only when using fingerprint login method. If I entered username/password I was able to get in. I tried rebooting the base station, force stopping the app on my phone, both did not work. It took uninstalling the app entirely and re-installing it. I know this is some sort of bug because my wife's phone is doing the exact same thing and started at the same time. Has anyone else encountered this and if so, aware of any known issue?
Same issue here. Running 20031 on a Pixel 2. Had been working fine, but not since the app update.
I contacted Arlo Support via CHAT today, just to make sure that someone at Arlo is aware of the issue... I'm a newbie here, so wasn't sure if Arlo was monitoring the boards or not.
The rep assured me that Arlo engineers were aware of the issue. Chat suggested if I was having the problem to kill the app, clear data, clear cache or also uninstall and re-install the app. Not sure why I would do this if it's still an issue that isn't resolved as I assume it'll just restart again - as that's happened with others in this thread.
But, it sounds as if they're working on it. Just fyi!
I have done remove/reinstall on my cell phone and on my tablet (both Samsung). I still get the same message, makes the usage of the system difficult !
I hope that in case of detection I will get a warning on my mobile devices but I'm not sure it works.
I hope Arlo will solve soon the problem. I don't understand it takes so long since this problem didn't exist on the version of software one week ago.
- FR.
My guess is they broke something session related when the program gets sent to run in the background
This is non-sense I am a premium subscriber and pay an annual fee every year, and I have spent hundreds and hundreds of dollars on this system. Now I have to deal with logging into my account everytime?
Not to mention, obviously customer service is nothing to rave about.
FIX IT!
@castleshade wrote:
Now recently when I go to the Arlo app it says my session has expired and a half to login again.
Which app? Android? iThing?
Just another user
The initial post already has this info - it's ARLO App.
There are apps for both iOS and Android - you didn't specify. The workarounds are similar but the steps are different.
Arlo is the system you are trying to connect to. It is not the platform that your "app" runs on.
The manual explains what is going on. Page 8 in my version.
Just another user
I see your point.
I'm using the Android app and after a while when you come back to the app it says your session has expired so I have to force close and reopen this is a new situation that hasn't happened previously. I think it's the updated app that's causing us
I don't see this. I have version 2.4.9_20032. Released last week.
Does "after a while" mean that it sometimes happens? Or is it every time you go back to the app?
Occasionally this, and other apps, want me to sign in. I put this down to security paranoia on the developers' front. Which does not seem unreasonable to me. But every time I used it would be a pain.
Just another user
After awhile of not opening the app. It will say your session has expired please login. So at that point you force close the app start it up again and it works and you don't have to login
Wait, 2.4.9_20032? I thought the latest from laar week's update was 2.4.9_20031.
True. Finger problems.
Just another user
