2 days ago, the 4 cameras connected to my basestation (video doorbell, 2 Pro 2’s and a Pro) all went offline at the same time. They were completely unresponsive so I removed all of them from the system and attempted to re-add. After attempting to sync multiple times and hard resetting all devices, I am having no luck. I was able to add the doorbell back as a stand-alone device and my Arlo Q has continued to work great. After an initial support interaction, where they wanted me to do what I had already tried, I have not hear back for a couple days. Everything is also out of warranty :(.
Anyone experience anything similar and have some advice?
STart by removing the base and cameras associated with the base from Settings, My Devices. It may be worthwhile to press and hold the reset button for >10 seconds, until the LEDs flash amber. Let the base reboot to green LEDs for power and Internet. Claim the base normally and then sync the cameras. Be sure to only briefly press the base sync button - don't hold it for 2 seconds.
I appreciate the tips, but as I mentioned in my original post, I have hard reset the basestations, and removed all devices from the account. The basestations activate right away, it's once I try to add the cameras that nothing happens.
I also have 2 basestations that I have attempted this on, and neither is working. I guess it could possibly be a network issues, but I was about to add my Arlo Q and Doorbell which don't need the basestation. I also haven't made any network changes recently. Definitely stumped.
Then it appears to be a hardware issue with the base that can't be handled here. Use support to see if a replacement base can be had under warranty.
