Had this issue on May 21 and it is back again
The Arlo Pro 2 cameras I have 3 cameras on one Base Station and 2 camera's on another Base Station.
The one with 3 camera's show that they are recording and I get yellow man running,
But it does not save to Library.
Also it shows when I look at overview of cameras (lower left) 1Min or just now so it is recording something. And you see the image of what it did record
I can not find the footage.
I have rebooted get all lights green on base station so that looks good
I am stumped what is going on
Is there a new filmware happening or what???????
Anyone having same issue Date May 21, 2019 6:00 PM Eastern Standard time now new date May 23, 2019 5:30 PM EST
This thread has been solved by Arlo so best start a new thread for attention. Hopefully it will not get merged like all the others.
I can view the video feed live, but my last recorded video was from a day and a half ago, at 2:49 PM on 5/24. That video was cut off at just 3 seconds, so it seems like there was some kind of sudden service failure. I have been coming and going from the house all day, and I have not a single recorded video since yesterday afternoon. I see that the Arlo status page says that "all systems are operational," but this delay seems to suggest that, at least for some users, this problem has not been resolved.
Then check your running mode status is correct, schedule is not working for me at times. Try forcing a basic or custom mode.
Then restart the base via the app and see if it starts working again.
Edit:
Some users here have said that resyncing all cameras can work also.
Hope this helps.
Has this been resolved as mine is doing the same as of Friday 24/5/2019 getting notifications but when I go in to watch the video it says no recordings 😳😳 base station has all green lights on very frustrating
Absolutely positive Arlo reads and actually will reply with more than a stock written script.
Even my support ticket contained a script of yes and no haha.
What stood out the most was... Told cx to wait
The time zone on my system is correct (EST). I have only used the default "Armed" mode; I do not use Schedule mode. I did try restarting the base station from the app, as well as creating a custom mode. Neither solved my problem. I still am getting no recordings of videos.
I'm currently getting alerts to my emails about an hour and a half after the cam activation..... I'm not sure if this is an arlo problem or an email provider problem
Try changing the motion sensitivity to another value to see if will start triggering the recordings.
Thanks for your conformation that the motion sensitivity change has nil effect.
I noticed on Friday that there are 11 hours of missing videos in my library. I know there were several instances of motion during this time on the 2 cameras on this hub. The library shows recorded videos before and after that window of time. I see this issue posted on here a lot, but can't find any clear resolution. Any help would be appreciated. Thanks!
Hub model VMB3010r2
FW version 1.12.2.1_2798
ARLO FIX IT
MY DAUGHTER SAID A GUY WALK INTO MY BACK YARD AND LOOK AROUND THEN LEFT. 11:19 AM MAY 27, 2019.
YOUR SYSTEM DECIDED TO SHUT DOWN AT 11:02 AND NOT COME BACK UP UNTIL 11:54
SO GUESS WHAT ................... NO PICTURES ........... THANK YOU FOR YOUR SUPPORT AND A SYSTEM THAT I CAN TRUST........ FIX IT
Now mine disarms on it's own. Several times now.
Arlo had some kind of ourtage on their service on May 25th... Now my notifications no longer work AGAIN!!! I am on the call with Arlo support and these guys ALWAYS tell me to wither remove the device or remove the battery.. All my 8 cameras notifications are not working. Do I need to do this for all CAMERAS!!!
Arlo is so crap. There is not a week where I don't call Arlo support for some issues.
Get the RING. I promise it will be better. My clients I install the RING, they never call me. Clients who I install these stupid Arlo always call me telling me their cameras does not work, live view lags, and notification stops working.
We need to press charges on these guys for crap products and service
No motion detection today
I hope they fix it before it soon
I just got off the phone with Level 2 support. This issue is now fixed.... After the outage on May 25th, they had to "resync" something on their cloud backend just now for my Android and Ipad to work getting notifications.. I did not make any changes myself. The engineer was very good but for me to resolve this issue, this was not something I could had done myself. This is what's frustrating when Arlo has outages. They have to "fix" something on their side to resolve your problem. In my case, notifications were not working on my Ipad and Android devices although it was working on my iphone.. now all three devices were working without myself doing anything besides waiting on the phone with support for over 1.5 hours..
I will no longer recommend my clients or anyone I know to buy Arlo's. This company if not change will go down the drain. I see a bright future for RING but not Arlo.. stock is going down anyways and I am not suprised!
