I recently recharged one of my 3 Arlo Pro Cameras. As soon as I did this the lens has moved to a 90 degree position and the focus is poor.
without touching one of the others one of them has now done the same.
Is there a fix for this?
Support were superb and fixed the issue. The battery needed replacing.
Are you saying the image has been rotated 90 degrees? Or that the lens has rotated somehow?
Perhaps contact support. https://www.arlo.com/en-us/support/contact.aspx
The image has turned.
The quality of the image is also really poor - to the point of not being able to see the picture due to blurriness.
