Efter mine vase var offline slettede jeg basen, da jeg ikke kunne få det til at virke. Nu jan jeg sket ikke oprette basen igen. Har haft taget strømmen. Alle 3 lamper lyser grønt.
Hvordan går jeg oprettet basen igen.
UPDATE (6/1): Adding Google Translation (from moderator):
"After my vase was offline, I deleted the base as I couldn't make it work. Now I did not happen to set up the base again. Have taken the power. All 3 lamps glow green. How do I set up the base again."
Hi BirkerødDK,
You may need to manually factory reset your Base Station. Read here to learn how to factory reset: How can I reset my Arlo SmartHub or base station to the default values?
If I seek help from the link you submitted, the page is unavailable
I would suggest contacting the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
