Help! I try to check support but it's not clear what you suppose to do!
I want to mode section and device section to adjust the sensitivity but no success! There's no save button and it keeps going back to default!
How do I adjust and save it???
Edit your recording mode. Edit your rule for that camera. Next to "motion is detected" is either a > or a pencil icon. Click that. Then change the slider. The click back. Then click save
Oh... I see it now. You have to click back and than click save. They made it so confusing! Thanks! 🙂
