  • 4 Replies
  • 1864 Views
Simk1n
Bought myself Arlo 2 Pro with 3 cameras.
Setup went smooth, installation very easy. Nice interface and everything was working fine first day.
But i have issues with the Activity Zones.
I first setup zones for all three cameras and it worked fine. I have since been adjusting the cameras and even switched position on one of them. All of a sudden yesterday two of the cameras did not work/record movement. It did not record any movement, or give me any notification. The running man is BLACK, and i can see it switch to yellow, so it is seeing the movement. I had to reset the base and add all thre cameras and it worked again.
Today, i have been been adjusting the cameras again, small adjustment, and therefore i have also been adjusting the Zones also. It seems to me, that if i first set up zones, and if i later adjusting them the problems start.
Is this Normal or what am i doing wrong? Today i have not reset my base, but pulled battery and re-add the non working cameras, but nothing. If i remove the Zones, they record movement and give me notification, but as soon as i add zones, they refuse to work. Live view works fine The last camera has been working fine today, but two is not..
I have made Rules also, so im not on Armed.
ShayneS
Hi @Simk1n
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Simk1n
All three cameras have been working fine since last weekend, and i have set my zones.
But i needed make som change to my zones, and after that it wont work again. I deleted the zones, set new ones, rebooted hub, set new rules but still nothing.
What am i doing wrong?
ShayneS
Have you tried to reboot the cameras? You can also create the zones over the web browser then reboot the cameras & test again.
Simk1n
No, i have not rebooted the cameras today.
But, i deleted all zones from my three cameras, and made new ones with my phone (Galaxy S10+ Android 9) and then it detect motion. If i check the zones on my computer, on my first two cameras, two zones are green and one is gray and cannot be edited. My last camera i have only one zone and that one is gray, and cannot be edited on my PC.
Usually its Green for Zone 1, Blue for Zone 2 and Gray for Zone 3 on PC.
  • 4 Replies
  • 1865 Views
