AC power on no battery = no recording. But will record when it's on full charged battery.
  • 1041 Views
barling9
My camera is running from power source but will only continue if full charged battery
How old is the battery ?   Possible sounds like a bad battery. Have you swapped the battery around to another camera?
Under a year then maybe possible warranty; contact Arlo support
barling9
Batteries fine, question is the ARLO site states under power no need for battery, so my question related to that system will not work solely on AC.
Yes, the camera SHOULD operate with or without the battery installed while on ac....
If it will not, other than the power source being used ( is it original with original cable ? ) , have no clue.
  • 1042 Views
