Hi Communauty,
I would like to setup thie following scenario. Currently i have 1 base en 4 cameras. 2 are outside my Home, 2 are inside.
Cams outside should be always Armed (Detect move)
Cams inside could be armed or desarmed (Armed when Alarm is on, Disarmed when Alarm is Off). Currently it's work well with Ifttt but for all cams
If i purchase additional arlo base and connect external cams in this base, is it possible to have one base always armed for external cams and second arlo base dedicated to internal cams configured armed or disarmed alternatively.
Thx for your help.
One of the nice features of more than one base unit is that you can arm each one ( arm/schedule/etc ) separately
and still all the cameras will appear in the same web/app ( if you service level supports the number total of cams )
I use multi bases to split front cams from rear areas of home.
Thx TomMac. It's perfect !.
Regards
Sébastien
