Pro 2 1 Of 5 Cameras Is Offline
Pro2 six camera set up. Five of the units are rock solid. One is a pain. So two of the cameras are side by side. One on each side of a support beam. This helps with the question is it out of range. The other camera works fine. I have even moved it. Still the same. Remove and install battery and all is good for a little while. My question has anyone else had a camera that just will not stay online? I am a damn good trouble shooter and have been through the gambit. But am also open minded to new tricks?
Have you just swapped the 2 cameras around? That would help figure out if it's the camera or location (the beam may be absorbing signal).
